Old 10-08-2015, 04:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Changing power steering fluid
Old 02-15-2010, 05:55 AM
StriderTacticaL
StriderTacticaL's Avatar
Default Changing power steering fluid
So I think it is time to change the power steering fluid on my car since I've never done it before. The cars got just under 46k miles and I bought it with 27k. I read that if the fluid looks dark brown then I should be replacing it. I just took a look into the resovoir and it looks really dark brown, like mud.
So anyhow, whats the best power steering fluid to use and how do I change it? I read that I can just suck up as much as I can from the resovoir and replace it with new fluid then drive the car around for a bit and repeat the process a few times.
Thanks,
Brandon
StriderTacticaL is offline
Old 02-15-2010, 09:11 AM
DreamerGT
DreamerGT's Avatar
yeah you can suck most not all of the fluid, and refill it and drive then do it again. Just do a few time and be all good.
DreamerGT is offline
Old 02-15-2010, 11:27 AM
Z28KLR
Z28KLR's Avatar
Probably don't even have to drive it. Just start up and move the wheel back and forth, lock to lock, a few times until the fluid has circulated (same process as when you replace a p/s pump to remove air bubbles).
Z28KLR is offline
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Urambo Tauro
09-07-2015 12:47 PM
jpplaw
08-22-2015 09:29 PM
antipeterleague
08-18-2015 01:50 PM
Quick Reply: Changing power steering fluid
