need help installing heads
so i have takent the heads off of a 2v. i marked the cam when it was at TDC. when i took the chain off, the cam moved due to the spring tension. i know there is a tool to hold it still, will i need that tool to put the cam back in time?? or is there another way to do it??
yea i marked em and the bolts come with the rotating assembly kit. see im replacing the entire bottom end but i need to hone my cylinders before installing pistons so i needed to take the heads off.... also how would i go about setting the cams back in time?? when i try to match my marks its a suna gun to turn the thing...
Luke9222
10-22-2015 11:55 PM
