How do i know when to rebuild rear end?
Old 04-21-2010, 03:14 PM
BlackMage
BlackMage's Avatar
Default How do i know when to rebuild rear end?
long story short, feels like im getting a lot of 1 wheel wonders going around corners more often than i use to on my 96 gt. How can i tell if i need to start lookin at rebuilding it? thanks.
BlackMage is offline
Old 04-21-2010, 03:20 PM
K Z
K Z's Avatar
I plan on it when I get some gears.
K Z is offline
Old 04-21-2010, 03:26 PM
BlackMage
BlackMage's Avatar
i already have gears and thats not even close to an answer for my question
Old 04-21-2010, 06:01 PM
grogan
grogan's Avatar
unless ur running a spool in the rear, going around corners one tire is going to spin the opposite way. and ull only get a 1 wheel peel. if its doing it in a straight line take off, then your either low on rear fluid or you can get ready to kiss the rear goodbye
grogan is offline
Old 04-22-2010, 05:40 AM
uberstang1
Chupacabra
uberstang1's Avatar
The last part of that post is totally false, in a straight line if ur only spinning one tire this by no means would indicate that you're rear is going to blow up any day now, all it means is the clutch packs in the differntial are worn out and it can be driving like that for miles and miles without blowing up.
uberstang1 is offline
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
Dragonus18
09-09-2015 01:21 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: How do i know when to rebuild rear end?
