Poly motor mount question
Old 05-05-2010, 05:45 AM
uberstang1
Chupacabra
uberstang1's Avatar
Default Poly motor mount question
Installed poly motor mounts along with my tubular k member setup and it seems like i expereince some noticable vibration at idle but it does go away once u start driving. Should there be a large vibration difference between stock rubber style mounts and the poly? It just seems more than i expected.
uberstang1 is offline
Old 05-06-2010, 05:29 AM
uberstang1
Chupacabra
uberstang1's Avatar
No one is running polys?
Old 05-09-2010, 11:47 AM
smashten
smashten's Avatar
I haven't noticed a difference. Do you think the k-member is worth the $? Getting ready to do some suspension work and would like to go with coilovers / tubular K.
smashten is offline
Old 05-09-2010, 06:58 PM
JayC
JayC's Avatar
Normal, you'll get used to it.
JayC is offline
Old 05-09-2010, 09:30 PM
yamanx
yamanx's Avatar
The poly will vibrate more as you are feeling the vibrations from the motor sense you switched to a poly mount. Plus side to the poly is that since it is a harder rubber you transfer a little more power since the motor is held in tighter and they last much longer than OEM mounts.
yamanx is offline
Old 05-10-2010, 03:39 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
You installed motor mounts with isolators made of a much "stiffer" material than the OEM rubber isolated mounts--what did you expect?
cliffyk is offline
Old 05-10-2010, 06:50 AM
uberstang1
Chupacabra
uberstang1's Avatar
I did expect more engine vibration, but the extent to the vibration was extreme, but after futher inspection one of the primaries on the newly installed long tubes was laying agaist the subframe in a spot, the problem was remedied and the extreme vibration is gone and it now feels more reasonable. I would recommend the QA1 tubular k and a-arms, I had zero problems with the installation and it bolted right up no issues.
Tivo304
08-28-2023 12:19 PM
Granatelli Sales
01-20-2020 12:34 AM
Luke9222
10-22-2015 11:55 PM
StalkerGT
09-25-2015 02:41 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Poly motor mount question
