cc plate question
cc plate question
i just put my cc plates on a today i had a couple questions about it first when i went to put strut back in place i jacked the a arm all the way up then i went to go to put the bolt on top of the strut and there wont enough threads sticking out so i could start the bolt.So then i lowered it back down and took the bump stop off and put one half that size on there then i had enough thread so i could start the bolt.When i put the car on the ground and drove it it sounded like somthing was loose every time i hit a bump plus it still looks like its towed in like it was before i put the plates on there has any of yall had this problem before
if you have the MM c/c plates ignore the instructions about placing the spacers. i put all of the spacers but one thin one under the plate. if you try it another way the strut can make contact with the hood. this isn't always the case though. try different combos until you find the right one.
another thought is that you didn't tighten the top strut bolt enough.
thanx for the info i messed with it a little more swicthing spacer's and all but it is stiil the same the only thing i didnt put back on was the dust cover i dont think that has anything to do with it
i fixed the tow and the clunking when i hit a bump i took out 1 spacer to fix the tow and under the cc plate there was a loose washer with threads i dont know what to call but it made the top of the cc plate were the strut goes loose
maestro1024
09-21-2015 02:40 PM
ccdguy
09-19-2015 05:20 PM
