Fuel pump wiring
Fuel pump wiring
I recently just finished completely installing my Glenns Performance 1000hp fuel system. Setup is:
Sumped tank
Dual Walbro pump
Inline filter
y block
upgraded feed lines
Adjustable FPR
Only thing I have left to do is the wiring for these new pumps. I didnt seem to get any sort of directions with the fuel system for this. Does anybody have any input on this?
Thanks guys
Sumped tank
Dual Walbro pump
Inline filter
y block
upgraded feed lines
Adjustable FPR
Thanks guys
I pulled power from one of the fuses under the dash that got hot with the key on. Then ran it back to the plug for the pumps on the fore hat. I don't see why you couldn't do that and just split it into each pump. Make sure you run a big enough wire to support both pumps. The stock harness wasn't up to the task of running both of mine.
jaiidutch
09-14-2015 10:29 AM
