Fog Light HID's
Old 01-21-2012, 04:41 PM
OneSik03
OneSik03's Avatar
Default Fog Light HID's
Ok, I got my HID's installed for my headlights and they look amazing. I am currently trying to install some in my fog lights and am a little stumped. How do I go about wiring it? Do I have to use the factory harness and if so, then how?? I can't figure out how to get power to them. The HID bulbs have two wires with metal ends that I can't figure out what to do with. Someone please help me.
OneSik03 is offline
Old 01-21-2012, 05:24 PM
stevednmc
stevednmc's Avatar
I replied to this in the other thread. Did you get a kit or just bulbs? What kit did you get? Link?
stevednmc is offline
Old 01-21-2012, 06:04 PM
vargas
vargas's Avatar
It's a plug in play type instal. It's not like the main headlights where you needed a power supply. The kit i got was just male pins that you stick into the existing wiring harness that connects to the light bulb then I taped them with electrical tape. My car's fogs gets its current from the main headlights so there was no need for a power source or ground connection.
vargas is offline
Old 01-21-2012, 08:23 PM
StockD15b
StockD15b's Avatar
do you have a picture? Because HID bulbs need a ballast. Kinda what makes them so bright.
StockD15b is offline
Old 01-22-2012, 12:36 PM
vargas
vargas's Avatar
I don't. I would but its raining out and don't have a garage. So the ballast connects to the existing wiring harness for the foglights. It goes as follows; existing wiring harness for the fog lights>ballast>foglamp>foglamp housing. As I said all I did was tape the connection so water wont get in.
vargas is offline
Old 01-22-2012, 10:37 PM
hpwrestler220
hpwrestler220's Avatar
Take wiring harness from the stock foglight connection and hook it into the ballast. Put HID foglight bulb into the foglight housing. Put the 2 connectors from the HID bulb into the other 2 connectors from the ballast. Use the 2 male connectors with the metal ends from the HID bulb and hook them back into the leftover harness.
Whether you hook the 2 metal connectors back into the HID bulb connector or back into the stock foglight harness, it's not going to matter if that's what you are asking.
The metal ends can connect to whichever connector you want. When I installed mine, I accidentally installed one light with the metal connectors running to my stock harness and one light with the metal connectors running to the same connection on the HID bulb. They fired right up and I didn't notice it until i changed my bulbs out for a color change. So there is no way to mess it up, really.
hpwrestler220 is offline
Old 03-25-2012, 09:32 PM
zada230
zada230's Avatar
zada230 is offline
Old 03-25-2012, 10:23 PM
caaraa
caaraa's Avatar
Ahh! I stand corrected then, Thanks for clearing that up.
caaraa is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Explosive
10-02-2015 07:45 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Fog Light HID's
