Electrical Issue? I'm stumped
Old 02-26-2012, 10:41 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Well I just stepped out into the garage and found something I was not aware of. My '03 GT has the Mach 460 system and you can load and unload CDs with the key off--in 5+ years of owning the car I was unaware of that capability...
cliffyk is offline
Old 02-26-2012, 11:29 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
My old GT the battery would drain really fast. Bought a new battery, new alternator and still had the problem.
I found out the GEM module (I think that's the name) was causing a constant power draw even when the car was off. My mechanic told me which fuse controlled the module (fuse #39 in the interior fuse box) so at night I would pull that fuse and the battery never drained again. I had planned on getting a replacement but never got to it before selling the car.
WannaBeGearHead is offline
Old 02-27-2012, 01:30 AM
Phaxtor
Phaxtor's Avatar
I had an expedition with the 460 and never knew I could do that til now... I sold the thing 3 months ago and have had it since 04 rofl
Phaxtor is offline
Old 02-27-2012, 09:16 PM
kast1376
kast1376's Avatar
Originally Posted by trexflyer
I had the same issue with my explorer a few yrs ago. Replaced the starter cable/wire and everything was fine. Battery was an old pos so replaced that. 2 months later replaced the starter and everything was fine for another month or so. Thinking that it couldn't be the new starter wire, and everything else was replaced I was stumped. Turns out the old battery corroded the inside of the new wire in 2 months and that ended up being the main culprit (again).
I guess it's possible the remote power lead going to the stereo amps is causing them to stay on all the time? But that would involve other issues with the radio/wiring as well. My random starting issues were just that....random. Sometimes it would go for over a week starting fine, other times I needed a jump right after turning the car off n driving for 200 miles.
I would say a corroded cable is your best bet, as already posted. If it is corroded inside, there could be enough resistance built up where the alternator will not charge the battery properly. If your previous battery had corrosion, it is very possible to have it get into the wire. When I replaced mine I had to chop off a good inch or so as the corrosion had been moving slowly away from the terminals.
kast1376 is offline
Old 02-27-2012, 10:25 PM
Kenny_k82
Kenny_k82's Avatar
Ha, I'm glad I found a feature no one knew about... I'll go ahead and check the starter wires if I can reach it with the car on ramps. Thanks for the input. I'll probably check it this weekend.
Kenny_k82 is offline
Old 02-28-2012, 12:41 AM
trexflyer
trexflyer's Avatar
In my case above it wasn't that the battery had any issues getting charged, it just wasn't getting enough amps to the starter to get it running. But it did have the all telling solenoid "click" like a dead battery. Put jumper cables on and it fired right up.
trexflyer is offline
Old 02-28-2012, 03:55 PM
Kenny_k82
Kenny_k82's Avatar
Well, mine doesn't instantly click, it will turn over a couple times and then click.
Old 02-28-2012, 06:25 PM
wolverine8490
wolverine8490's Avatar
Do you have keyless entry? If so, do you lock the car with the remote every night?
wolverine8490 is offline
Old 02-29-2012, 12:14 PM
Kenny_k82
Kenny_k82's Avatar
The car goes in the garage so I don't bother locking it at night
LiquidDrink
09-29-2015 10:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
stangin1996gt
09-21-2015 11:01 AM
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: Electrical Issue? I'm stumped
