Old 10-26-2015, 02:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Oil Leak, can't figure out from where!
Old 04-09-2012, 12:58 PM
V8_silverstang_V8
V8_silverstang_V8's Avatar
Default Oil Leak, can't figure out from where!
I was driving my 2000 GT on the freeway the other day when smoke started to come from underneath my car from an oil leak that was touching the exhaust. The car only leaks oil when I'm driving, no leaks in the driveway, and only leaks a lot when I'm at high speeds on freeway. I lifted the car to try to locate the leak but i had no luck finding where the leak was coming from. I think it is getting worse. Has anyone had the same problem? Any ideas where the leak might be from? Is that dye for locating leaks a good method? Anything helps. Thanks in advance.
V8_silverstang_V8 is offline
Old 04-10-2012, 01:05 AM
Xemeth
Xemeth's Avatar
Can you see any oil/fluid under the car?
Best bet is to clean everything off with degreaser and hose it off and dry it. Then add some florescent dye to the oil and drive it in the condition where you say it leaks. Then go back under with a black light and the leak detection glasses and you should be able to see where it's coming from.
Xemeth is offline
Old 04-10-2012, 01:13 AM
JeremyB
JeremyB's Avatar
I would start with valve cover gaskets for sure, that would only leak when it's running like you are describing
JeremyB is offline
Old 04-10-2012, 02:45 AM
MyGt03
MyGt03's Avatar
^^^ +1 on the valve cover. Its directly above the exhaust manifold and would only leak while driving.
MyGt03 is offline
clowe1965
Carolina Regional Chapter
34
09-28-2015 09:18 PM
TfcCDR
09-12-2015 04:13 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Oil Leak, can't figure out from where!
