Slapping/Flapping Noise MOTOR/UNDER HOOD- NEED HELP - THANK YOU :)
Alright this has recently started happening. 2001 GT Automatic
When hit the throttle just a bit the car accelerates very slow and there is a flapping/slapping sound from the motor/under the hood.
Even if i am going at 40 MPH i let go of the throttle the flapping goes away i touch the throttle raising about 100 RPM it flaps. At any speed if I let go of the throttle it sounds just fine there is no slapping noise, now i press down just a bit enough to get the car to maintain speed it flaps.
While cruising without hitting the throttle perfect i touch the throttle to accelerate just a tiny bit it flaps and it feels weak while accelerating if I push down on the throttle more it sounds just fine.
Only happens when i accelerate and when i push down on the throttle just a tiny bit.
I recently put in new intake manifold / X Pipe ( Catted ) & SLP 2 Exhaust
What could cause this anything will help.
THANKS IN ADVANCE
THANKS IN ADVANCE
UPDATE - Throttle body seems fine.
It happens now matter what it just goes faster when i hit the throttle it never goes away.
I think it has always been like this, it just flaps faster as the throttle gets pushed down more sounds from the driver side of the hood and only happens when i accelerate.
SOUND CLIP :
http://soundcloud.com/marlon-batista...slapping-sound
SOUND CLIP :
YEP I bought new ones and the shop put them in.
New gaskets from Exhaust Manifold/Headers to X Pipe/Mid Pipe
I've been thinking its a leak somewhere sounds like loosing air.
I think that the gaskets I got SUCK !!! Since i bought them from Auto Zone for like $6.00 each i noticed they were very thin but i am not 100% on what the problem might be will be taking it to the shop that installed the X Pipe and Exhaust Friday.
Any suggestions are still welcome that way we can pin point the problem !
THANK YOU ALL
THANK YOU ALL
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
ccdguy
09-19-2015 05:20 PM
