Ice Damage?? Bad crank sensor, what now??
Old 02-28-2013, 06:40 PM
tracyballard
tracyballard's Avatar
Default Ice Damage?? Bad crank sensor, what now??
OK, I was driving to work today in my 140,000 mile 2002 Mustang GT, and all of our snow hasn't melted yet, so I ran over a big hump of snow in the middle of the road. It scraped the bottom of my car for about 30 feet, and shortly thereafter my check engine light comes on. Now, it's running really rough, and I took it to Autozone to check the codes. They came up with 0305 and 0316 - bad crankshaft sensor condition and misfire on cylinder 5. I checked the crank sensor and did not see any obvious problem, nor any obvious problem with the plug wires. What do I do now?? Is there a way to check this crank sensor without replacing it? Do you think that's really the problem?
tracyballard is offline
Old 02-28-2013, 09:48 PM
FrostByte
FrostByte's Avatar
Look under car, make sure you didnt rip any wires out , like o2 sensors.
FrostByte is offline
Old 03-02-2013, 09:48 AM
FlamingoGT
FlamingoGT's Avatar
If you hadn't said something about riding the ridge, I would have suggesting checking the alternator. But with that said, I agree with checking over the wiring on the underside. If the sensor isn't reading, whether from the sensor being bad or a broken connection somewhere, the engine won't run quite right which could cause the misfire too. So fix the sensor issue first and that very well could fix the other issue.
FlamingoGT is offline
StalkerGT
09-25-2015 02:41 PM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Ice Damage?? Bad crank sensor, what now??
