Headlight Problem
Old 04-24-2013, 09:13 PM
YellowRoushPony9477
YellowRoushPony9477's Avatar
Default Headlight Problem
So here is the issue. 03 Roush, stage 1, basically a GT with some body mods but original Roush. I turn on the low beams and they work intermittently, sometimes they work and sometimes they don't. However, after bringing it out of storage this past weekend, they would turn on, then after a few minutes of driving, they would just turn off randomly. The high beams work fine, but I would have to flash the highs for the low beams to come back on. Any suggestions? Or should I just take it in and pay the enormous price that Ford charges?
YellowRoushPony9477 is offline
Old 07-28-2013, 09:23 AM
aframe
aframe's Avatar
Im having the same problem did you find anything out
aframe is offline
Old 07-28-2013, 12:10 PM
Stevo86
Stevo86's Avatar
Sounds like a relay problem. Open up the fuse panel under the hood and find the headlight relay. Swap it out with a known good relay like your a/c compressor clutch relay and see if that fixes the problem. If so, go get a new one and stick it in there.
Stevo86 is offline
StalkerGT
11-28-2015 03:09 PM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
ccdguy
09-19-2015 05:20 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Headlight Problem
