went to the dyno today...results seem low (plot inside)? 2000 GT with bolt-ons
Old 06-03-2013, 01:16 AM
kingrukus
kingrukus's Avatar
Default went to the dyno today...results seem low (plot inside)? 2000 GT with bolt-ons
Went to the dyno today for the first time and ran 2 pulls. Not sure what to make of the results?
It is a 2000 GT 5-speed with ~55000 miles and the following mods:
Ford Racing Performance - SOHC 70mm Throttle Body
Accufab Upper Intake Plenum
Ford Racing Performance - Underdrive Pulley kit
Ford Racing Performance - 4.6L SOHC Headers
Ford Racing Performance 3.73 Gears
K&N - Air Filter
Bassani Catback Exhaust
Bassani Catted X-pipe
DiabloSport Predator 91 Tune
Is there any thing else bolt-on wise I should be doing to get more power out of her, before supercharging?
kingrukus is offline
Old 06-03-2013, 06:03 AM
xx10Gt
xx10Gt's Avatar
anything such as altitude and temp could affect a dyno run but with that being said a stock gt would put down around 220ish, so im not thinking those are TOO bad of numbers...
Anyways maybe some cams would help her out a little bit, plus you'll get a badass loping idle
xx10Gt is offline
Old 06-03-2013, 12:53 PM
Z28KLR
Z28KLR's Avatar
A better tune could probably squeeze another 5 or 10 out of it. The Predator canned "performance" tune is a turd. Aside from that, your numbers fall within a pretty typical range.
Z28KLR is offline
Old 06-03-2013, 05:37 PM
T.Richardson
T.Richardson's Avatar
Looks normal to me.
T.Richardson is offline
Old 06-03-2013, 07:19 PM
moncherou
moncherou's Avatar
that is strong for what you have. I did 240 before the s/c with underdrives, plenum, ported stock t/b, timing kit - moved the crankshaft sensor (+3 degrees where I had it set), k&n and weld in mufflers. you can keep all the mods except the underdrives when you add the blower if its a centrifugal type
moncherou is offline
Old 06-04-2013, 07:21 AM
uberstang1
Chupacabra
uberstang1's Avatar
Average numbers.
uberstang1 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
PaulH2
20
01-31-2016 09:48 AM
TCStangerv6
10-11-2015 05:57 PM
GLOCKer
09-28-2015 07:36 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: went to the dyno today...results seem low (plot inside)? 2000 GT with bolt-ons
