A/C Cooling issue.
Old 08-19-2013, 04:41 AM
Sauce03GT
Sauce03GT's Avatar
Default A/C Cooling issue.
My car's a/c started blowing hot. Not ideal here in South Florida. Checked the freon levels and they seemed to be okay, but had it emptied and refilled anyway. Was able to determine there was no power getting to the compressor. If power is directly applied to the compressor it appears to engage and still be functional. From what I found online, it looks like there is a CCRM before the compressor which may be the issue. Has anyone had this problem before?
I was having trouble finding the part number for the CCRM. I think I might of found it on ebay but I am not quite sure if this is it.
http://www.ebay.com/itm/BRAND-NEW-OEM-MULTI-FUNCTION-RELAY-2001-2004-4-6L-FORD-MUSTANG-1R3Z-12B577-AA-/281135071502?pt=Car_Audio_Video&hash=item4174f4c10e&vxp=mtr
The other part number I found on ebay said it fit the V6 Mustang. Are they the same CCRM's?
Any help would be greatly appreciated!!
Sauce03GT is offline
Old 08-19-2013, 04:59 AM
dawson1112
dawson1112's Avatar
There is also a pressure switch on the line some place , if it goes bad the compressor wont kick on. That switch is what tells the ccrm that there is pressure there and it is ok to start the compressor. If the ccrm doesn't see the switch or the switch is bad it assumes the system is low and will not start.
Who vacated and refilled your system for you? I cant believe any one with knowledge of the ac system would have missed the reason for it not kicking on ..
dawson1112 is offline
Old 08-19-2013, 11:10 AM
Sauce03GT
Sauce03GT's Avatar
Thank you for your reply dawson1112,
I double checked with the guy who helped me and he did jump the switch and was able to determine that it was not the issue.
Old 08-24-2013, 04:05 PM
Sauce03GT
Sauce03GT's Avatar
I bought a new CRRM, and changed it. Easy job, located near intake in the passenger side front fender. My compressor kicked on right away.
BOB ROME
07-26-2023 01:54 PM
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: A/C Cooling issue.
