No start on 02 GT
Old 04-24-2014, 01:27 PM
holdtyte
holdtyte's Avatar
Default No start on 02 GT
Hi, Have a problem hoping someone can help me. Have an 02 Conv. That won't start. The starter just clicks. Have a new battery (load tested it to make sure it was good), Changed the starter, Checked the wiring for the solenoid and starter main power. good continuity. If i bypass the ignition form the solenoid connector beside the battery it does the same thing. While it is clicking the battery neg. wires get warm to the touch. Any ideas?
Thanks,
Ron
holdtyte is offline
Old 04-24-2014, 03:18 PM
DillonInCO
DillonInCO's Avatar
How many miles? I only ask because, if you're sure the wiring is good, that sounds a lot like a problem I had on another car, and unfortunately it ended up being a seized engine. My thought is the wiring would get hot if the starter can't turn the flywheel. I would try turning the crank by hand from the pulley with a breaker bar (or ratchet with a pipe) on the bolt that holds it in. I think it's a 12 or 13 mm bolt. If it doesn't turn with a little effort then you've got a more serious problem
Also possible you got a bad starter if you bought from a parts store. Not unheard of, especially if it's remanufactured. You might take it off and take it back to wherever you bought it and have them test it.
DillonInCO is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: No start on 02 GT
