2000 GT clutch fork
Old 07-11-2014, 12:41 AM
lman
lman's Avatar
Default 2000 GT clutch fork
The clutch fork on my 2000 gt is not coming out of the center of the opening in the bell housing. It is far enough off to one side that it has actually pushed a hole into the dust cover. This is also causing the dust cover to vibrate a lot when Im not pressing in the clutch. any idea why it would be riding so far off to the side?
lman is offline
Old 07-11-2014, 06:23 AM
dawson1112
dawson1112's Avatar
1 of two things has happened.
Either the clutch fork pivot ball clip is broken and its falling off the pivot ball, or the throw out bearing sleeve is broken , it which case it would be rattling like crazy.
Its possible that the fork just slipped off the pivot ball, but the cable would have to be pretty loose for it to do that. You can pull that cover and see if you can push it back on to the pivot ball. If not a transmission pull is necessary .
dawson1112 is offline
Old 07-16-2014, 12:41 AM
lman
lman's Avatar
Hey thanks for the reply. Just got my transmission out and found that the pivot bolt had backed itself most of the way out and was bent. The fork had slipped off of it as well.
lman is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: 2000 GT clutch fork
