No oil pressure on cold start.
Old 07-19-2014, 03:45 PM
havok209
havok209's Avatar
Default No oil pressure on cold start.
Oil level is fine. Only on cold start. Once I give it a bit of gas, it jumps up to where it should. Any suggestions on what to check?
havok209 is offline
Old 07-19-2014, 04:38 PM
Ogre
Ogre's Avatar
Oil pressure switches are well known for going bad on 4.6s. I had them same issue as you with my 01 GT. Turned out to be the oil pick-up was full of junk and became totally blocked. Luckily, I had the radio off and was only two blocks from the house when the engine started knocking bad. I ended up replacing the oil pump and pick-up and never replaced the oil pressure switch.
Ogre is offline
Old 07-19-2014, 04:53 PM
havok209
havok209's Avatar
Awesome, thanks. Since I JUST had the motor rebuilt no more than 5K miles ago. The car, as well as all the accessories on it, are at damn near 200K miles. I'm beginning to lean more towards a bad switch. I wonder if this is something I should do aftermarket in order to have a more accurate reading, even though I HATE gauges all over the place.
havok209 is offline
Old 07-19-2014, 04:56 PM
havok209
havok209's Avatar
However, why would it do it only when it's cold if it's a bad switch?
havok209 is offline
FivePointToTheOh
10-02-2015 04:09 PM
Meystang
09-25-2015 04:05 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
kevsgt
09-09-2015 06:20 AM
09-08-2015 11:50 AM
Quick Reply: No oil pressure on cold start.
