Stuck bolt
Old 09-10-2014, 04:14 PM
avatar14
avatar14's Avatar
Default Stuck bolt
My idler pulley fell off yesterday and I cannot bolt it back on because the told literally broke in half and is now stuck in the hole. Is there any way I can get it out or drill a new hole? Someone please help me!
avatar14 is offline
Old 09-10-2014, 04:34 PM
dawson1112
dawson1112's Avatar
The pulley came off of the idler, or the idler came out of the timing cover?
If its just the pulley you can replace the entire idler arm. You can also use a drill bit to make a hole in the bolt and then use and easy out to remove it. I have at times also welded a nut to the top of a broken bolt. Just weld it inside the threads of the nut.
dawson1112 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: Stuck bolt
