Still idle problems and CEL help
Old 03-01-2015, 05:14 PM
jawknee5
jawknee5's Avatar
Default Still idle problems and CEL help
Hey guy. I've been tracking an idle problem for a while and it's been getting the best of me.
It starts a rough idle after being warned up and stopped at a stop light it will gurgle but never die, idle drops to around 500 and kicks back up but again never dies.
So far what I've replaced is below, not all from chasing the problem but just general maintenance in the past few months.
Pcv valve
O2 sensors
Maf
Iac
Tps
Coil packs
Plugs with new wires less than a year
Fuel filter is new and fuel pump isn't that old
I just replied the EGR valve two days ago and now I'm getting a p0171 and p0174...
And tips?
jawknee5 is offline
Old 03-04-2015, 09:12 PM
jawknee5
jawknee5's Avatar
Just searched around with a can of carb cleaner for vacuum leaks and nothing jumped out, but I did spray some near the front of the new intake manifold I had installed and it seemed to bog down and sputter...
It's a dorman brand I presume from the look of it. Think it could have been installed incorrectly?
jawknee5 is offline
Old 03-08-2015, 11:23 PM
xoHollieNicole
xoHollieNicole's Avatar
I had an idle problem in my 02 and we thought it was the IAC or a vacuum leak, but we fixed it by following the steps I'll post below. It just needed an idle reset. We did replace a rubber piece before we did this and it helped it a little bit, but not completely. I can ask what that piece was tomorrow if you want. Anyways, I don't know if this would have anything to do with yours since it's 97 and mine is an 02, but I figured I'd share the info I have, I'm new to this stuff so sorry if it doesn't help! I figured i would at least try =] I got this from another site.
"DO NOT TOUCH THE GAS PEDAL!!
You will probably get a million different responses on how to do this. This is how I have done it and it works for me. And I've done it a lot.
1. Disconnect the negative terminal to your battery and turn on your headlights for about 10 minutes(there's a lot of speculation as to how long. some people will even say to disconnect the positive terminal and some people will say to leave it disconnected over night.)
2. Disconnect the wiring harness connector to the IAC
3. Turn off headlights and reconnect battery. DO NOT TOUCH THE GAS PEDAL!!
4. (People will probably argue over this step) DO NOT TOUCH THE GAS PEDAL!! Try to start the car. If the car won't start adjust the set screw on the throttle body a 1/4 - 1/2 turn and try again. Repeat until the car will stay running. It will run rough but that is what you want. (some people will say to turn the set screw a few turns before starting your car then turn it down until the car idles at 700rpm or so then)
5. Either way you go let the car sit and idle (DO NOT TOUCH THE GAS PEDAL!!!) until the car reaches operating temperature which to me is when the needle moves to the right leg of the letter 'N'
6. DO NOT TOUCH THE GAS PEDAL!!! Step 5 allows the computer to relearn idle settings. It's pretty cool when you follow my procedure because you can actually hear and feel the car figuring out the proper idle settings. It will go from idling rough to idling smooth as it warms up. Once the car is warmed up verify that the car is idling at around 700rpm. (this is where the scan tool comes in handy cause you can be more accurate but eye-balling it works too) If the car is not adjust the screw until it hits ~700rpm and then let is sit maybe another 10 minutes DO NOT TOUCH THE GAS PEDAL!!!
Turn the car off. Reattach IAC wiring harness. Now some people out there will tell you that this step is not necessary but I totally disagree. Remember we adjusted the set screw on the throttle body. That means that the voltage reading from the TPS sensor has changed. It should read between .96 and .99 volts. (someone correct me if I am wrong) Anything outside of that range will cause all sorts of issues including misfires and rough idle.
7. Now this part you may want to look up and verify before you go piercing wires. What I do is I stick the middle wire with a metal pin, a heavy sewing needle works pretty good (I think, it may be the top wire if you are viewing the connector while still connected) some people just peel off a piece of plastic wire cover because they have to do this so often.
8. Set your multimeter to volts. Turn your car to key, on engine off. then place your positive lead of your mutlimeter on the metal pin and your negative to some ground point. If it comes up as a negative that is okay as long as you are -.96 to -.99. If you get this reading then great you are done and hopefully your issues are gone. If not proceed to step 9
9. This is where and extra pair of hands come in handy. Using a large screw driver you will need to loosen the bolts that hold the TPS. DO NOT USE A SCREWDRIVER THAT IS TOO SMALL BECAUSE YOU WILL STRIP THE BOLTS. They probably will be really tight so you have to really lean on the screwdriver and use some finesse. They will come off. Just don't try to turn the bolt all at once or you will strip it. A lot people have broken their TPS from being too rough with these bolts. Again, I'm not a mechanic by any means but just use some common sense.
10. Once the bolts are loose you will need to move the TPS up or down and continue to read the voltage. Once you get it to the desired setting you can retighten the bolts. What I do is I find .97 and then as carefully as possible I tighten the TPS down. what will happen is the voltage will change usually to
.96 or .98 but that it okay. Once you are done with this manually open the throttle body a few times and close it then reread the voltage and make sure it is still within our desired range.
11. You should be good. I would put a little putty on the whole you made with the pin. Drink a dozen beers or so and crank you car. DO NOT TOUCH THE GAS PEDAL!! I would give the car a once over, make sure nothing came loose while you were messing around under the hood. Let the car idle for a few minutes then take her for a spin. You may want to wait on the dozen beers."
xoHollieNicole is offline
Old 03-10-2015, 08:44 AM
daveyg
daveyg's Avatar
good write up
daveyg is offline
Old 03-12-2015, 09:29 AM
raredesign
raredesign's Avatar
I am not trying to hijack this thread, but you really seem to know your stuff and I am going to be replacing my TPS as well. I have the BBK 62mm (please don't say throw it away), and it ran fine on the stock TPS for 3 years.
I don't remember what the stock voltage was, so I will try what you said. I also got some info from a dealer, and was wondering if it was correct.
They said TP 1 and TP 2 readings. I assume that means open TB and closed TB so that it can get the full range. Does that sound right?
Well, he said to get the readings with the engine off (I assume key on like you said), and it should be:
TP 2 - 1.2 Volts
TP 1 - 4.1 volts
I was not the one that spoke with the tech unfortunately. I called a local dealer and they said to call Ford, so I called Ford, they placed me on hold and gave me those values. I asked where they got them, and they had called the exact same dealer I had.
After calling that dealer back to get clarification, they said he helped once and they can't put the tech out again.
Any clarification is appreciated. Thanks!
raredesign is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Still idle problems and CEL help
