2001 Mustang gt front brakes.
Old 03-28-2015, 01:10 PM
EJA32
EJA32's Avatar
Exclamation 2001 Mustang gt front brakes.
Hello.
I am going to be replacing my front brakes, and all I need to know is what torque wrench setting do I use for the bolts and the guide pins?
Thanks for your time.
EJA32 is offline
Old 03-29-2015, 06:30 AM
dhavi4226
dhavi4226's Avatar
Originally Posted by EJA32
Hello.
Manual says 96Lb Ft. Seems like a lot to me. I personally have used the German measurement, Goot-n-tite on my vehicles. Never lost a brake caliper.
dhavi4226 is offline
Old 03-29-2015, 10:48 AM
Camster
Camster's Avatar
I agree.
I actually think that the torque setting of lug nuts is more important than this,but few guys take the time....I've never lost a wheel either.
Camster is offline
Old 03-29-2015, 06:01 PM
RMK01GT
RMK01GT's Avatar
would be closer to 25 ft/lbs for the calliper bolts
RMK01GT is offline
Old 03-30-2015, 09:46 AM
EJA32
EJA32's Avatar
Thanks again for the reply's. My next question is their a right pattern in putting in the pads? I ask because ask I was Finshing up on the driver side with the piston all the way down I could not get the caliper on, then I saw on the back of the back one of the rivets or stud or whatever its called its not flush with the back of the pad. Was is this made wrong or do one of theses pads go on the piston side of each caliper?
EJA32 is offline
Old 03-30-2015, 12:04 PM
unitedwestang
unitedwestang's Avatar
There is a piston side pad and a "not piston side" (for lack of a better term) pad.
At least there was on the last set of pads I put on I remember.
unitedwestang is offline
Old 03-30-2015, 01:16 PM
EJA32
EJA32's Avatar
Thanks I got them on the right way. Now I'm sitting in my car pumping the brakes and it does not seem like the fluid is going down that much. :/
P.s. I did not bleed the front calipers when replacing pad. I undid the brake master cap then pushed pistons back with c-clamp now I am trying to get the fluid back in to the lines.
EJA32 is offline
Old 03-30-2015, 01:44 PM
unitedwestang
Forgive me if I'm pointing out something you already know:
Without a vacuum bleeder, bleeding the brakes is almost a two person job. One person in the car pumps the brakes until the pedal gets stiff and holds it there. The other person loosens the bleeder nipple on the caliper and lets the bubbles and fluid out. Then retightens the nipple. Repeat the process until no more bubbles are seen coming out and only new fluid is coming out. Proceed to the next caliper repeating the same process. Start with rear passenger, followed by rear driver, front passenger, then front driver. I believe that is the correct order. You start with the caliper farthest away from the master cylinder then work your way towards it.
Old 03-30-2015, 02:34 PM
EJA32
EJA32's Avatar
Thanks for the replay westang.
I read the article from edmunds.com: http://http://www.edmunds.com/how-to...rake-pads.html (I read section 8)
This made a lot of sense, and after reading this I drove the car in my drive way to see how she braked and it felt good
EJA32 is offline
Old 03-30-2015, 02:37 PM
Derf00
Gentleman's Relish
Derf00's Avatar
96 ft/lbs is probably the caliper mounting bracket bolts to hub not the caliper slide pin bolts. The caliper mounting brackets are typically between 85-95 ft lbs. (86-89ft.lbs.on the 05+ mustangs for example))
Caliper slide mounting brackets are usually 35-36 ft lbs for the front and 25-35 ft lbs for the rear.
Derf00 is offline
MtnMustang
08-16-2015 08:07 PM
01moostanggt
Suspension
08-13-2015 07:48 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
tmdm
08-07-2015 10:24 PM
Quick Reply: 2001 Mustang gt front brakes.
