03 GT cruise control sticks
Old 05-30-2016, 01:57 PM
usaf1965
usaf1965's Avatar
Default 03 GT cruise control sticks
When i turn off cruise control the car will stay up to speed. And when I slow down and let off it gets back up to speed by itself. Any Ideas?? (Automatic)
usaf1965 is offline
Old 05-30-2016, 04:06 PM
Urambo Tauro
Urambo Tauro's Avatar
Am I reading that correctly, that your cruise control stays engaged when you brake, and even if you press the OFF button on the steering wheel?
I think the first thing you should check is brake light operation. If they are not lighting up when you press the brake, there could be a problem with the stoplight switch or the circuit.
That wouldn't explain the inoperative OFF button, though. It's possible that the switches on the steering wheel may have gone bad.
Urambo Tauro is offline
Old 05-30-2016, 09:29 PM
usaf1965
usaf1965's Avatar
from what it seems yes. Both brake lights work. Maybe i should unplug the cruise control fuse
usaf1965 is offline
Old 05-31-2016, 01:41 PM
Camster
Camster's Avatar
Maybe you should fix your idle rpm issue from a few threads down,before you introduce another issue,which might possibly be related to the idle issue.
Camster is offline
Old 05-31-2016, 01:53 PM
jwog666
jwog666's Avatar
the brake switch and the button are two seperate ways to cancel cruise, if neither work its most likely an issue with the cable that attaches to the throttle body. check it for binding and to make sure that the area where the cable slides into the outer shieth is in good shape, sometimes as the cable slides in it will get stuck. if that checks out make sure that there is nothing getting stuck in the throttle linkage itself.
jwog666 is offline
cobra40813
05-11-2016 12:10 AM
newedge661
05-06-2016 06:02 PM
Greg251
05-06-2016 08:02 AM
AMAlexLazarus
AmericanMuscle.com
05-05-2016 12:26 PM
Jojo2007
05-02-2016 04:49 AM
Quick Reply: 03 GT cruise control sticks
