Hard start on cold mornings?
Old 12-05-2005, 11:37 PM
AmericanRicer87
AmericanRicer87's Avatar
Default Hard start on cold mornings?
I have a 2000 Mustang GT, its kinda hard to start after a night in the 20's and bellow, anyone got ideas about whats wrong? The battery is charged fine it just doesn't catch like untill u crank for about 10-15 seconds and it will stutter start, then stall and it will do it once more and the third time it starts ands runs. help?!
AmericanRicer87 is offline
Old 12-05-2005, 11:39 PM
Slick97gt
Slick97gt's Avatar
Default RE: Hard start on cold mornings?
My 1997 gt will sometimes fire up and then die once on a real cold morning.
Normally after the second start it does great other then idling a little rough until it warms up a little.
Slick97gt is offline
Old 12-05-2005, 11:41 PM
Silver_Stallion
Silver_Stallion's Avatar
first make sure all power is turned off ( lights, a/c, radio, etc.) check battery connection ( big issue) then plugs for better fire...thats the first thing i would do...mine used to do the same thing...but runnin great now ...but start by cleaning the connection and check for corrosion!! check back, and good luck
Silver_Stallion is offline
Old 12-06-2005, 01:06 AM
kartracer55
kartracer55's Avatar
Thats just what happens when its cold out... nothing works right when its cold. Having a weak battery also doesnt help... you want to look at you Cold cranking amp rating... maybe its not sufficient enough for your area
Jim
kartracer55 is offline
Old 12-06-2005, 01:54 AM
racer02GTstang
racer02GTstang's Avatar
mine takes a couple seconds and then she starts right up. the timing is really out of wack so that could be why.
racer02GTstang is offline
Old 12-06-2005, 03:13 PM
mustang_montana
mustang_montana's Avatar
practically everything under my hood is new and i have some hesitation starting up. its cool though, cause it sounds badass once it gets going.
mustang_montana is offline
Old 12-06-2005, 06:16 PM
AmericanRicer87
I definately second that!
ORIGINAL: mustang_montana
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
antipeterleague
08-18-2015 01:50 PM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: Hard start on cold mornings?
