98 cobra questions
Old 12-07-2005, 09:22 AM
kpaver
kpaver's Avatar
Default 98 cobra questions
just had a few questions about my stock 98 cobra:
1) what is the width of the cobra R rims
2) whats the compression ratio
3) what gears are in the rear end
4) 4 bolt mains or 2
kpaver is offline
Old 12-07-2005, 04:46 PM
codyss
codyss's Avatar
Default RE: 98 cobra questions
1) Which Cobra R wheels? The 1995 Cobra R = 17x9 / 2000 Cobra R = 18x9.5
2) 9.85:1
3) 3.27
4) I would assume 2 bolt mains
codyss is offline
Old 12-08-2005, 04:20 AM
kpaver
kpaver's Avatar
are you sure about the gears? i thought they would a least be 3.55's. i thought the gt's had 3.27's but maybe im wrong. also, i was researching and found out that the cobra engines have 6 bolt mains (kind of). They have 4 bolts through the top of the caps and have 2 bolts that actually go into the caps from the side of the block. its like that on the 4 outer caps, and the center one only has 2 bolts in the top (which really doesnt matter that much).
kpaver is offline
Old 12-08-2005, 06:30 PM
codyss
codyss's Avatar
I forgot that they had large mains.
As for gears I am pretty sure that the solid axle Cobras did have th 3.55's
codyss is offline
Old 12-08-2005, 06:43 PM
757GT
I ♥ Acer
757GT's Avatar
A 98 Cobra has an IRS.
757GT is offline
Old 12-08-2005, 07:29 PM
OnyxCobra
OnyxCobra's Avatar
im pretty sure the '98 cobra has a solid rear axle and it def. has 3.27 gears as far as ive ever seen.
OnyxCobra is offline
Old 12-09-2005, 03:59 AM
codyss
codyss's Avatar
757GT Do you notice the trend? Your always wrong.
And yes the 1998 was the last year Cobra to have a solid axle.
codyss is offline
Old 12-09-2005, 04:03 AM
dawssvt
dawssvt's Avatar
yes, the gears are 3:27's. I changed mine out to 3:73's.
dawssvt is offline
11-10-2015 11:39 AM
Ipaman
09-22-2015 07:01 AM
04stangman
09-17-2015 01:45 PM
Sparks_88
09-08-2015 01:06 PM
Quick Reply: 98 cobra questions
