t45 drive gear swap
Old 07-09-2009, 10:14 AM
stangalator
stangalator's Avatar
Default t45 drive gear swap
So i recently had 4.1's installed, after my speedo was 50% fast! I chaged the speedo gear to a 23 tooth gear and i calcuated it to ~17.5% too fast... I'm not sadisfied i guess. I've been searching about and researching a drive gear swap and it doesn't look that hard, however my question is about the drive gear itself. I can't seem to find a site that sells a 6 tooth drive gear for a t45, only a t5. The sites say that its ONLY for the t5, so i'm guessing they are different gears. I can find a 20 tooth speedo gear fine but i can't find the 6 tooth drive gear, can someone help?
Here is some of my findings and figures i've done in case someone else finds this thread:
23 tooth speedo gear is not a ford part and doesn't go together perfectly, this causes a short life for the plastic gear. Since I'm changing the drive gear, i figured I'd do it right and get a combo that using a ford speedo gear and is closer to my orginal ratio by about half
18/8 oem is 2.25 ratio drive gears (2.73's) then final drive divided by ratio......1.2133333333
23/8 now is 2.875 ratio (with 4.10s).....................1.4260869 fast by...17.5346346 percent
options:
20/6 is 3.333............................................. ....1.23 fast by 1.373626 percent
23/7 is 3.2857142857...................................... 1.2478260869 fast by 2.8428 percent
"perfect" is 3.37912 speedo/drive gear ratio (for 4.10's)
here is a thread that helps out alot in removing the drive gear, thanks Popeye54k
http://allfordmustangs.com/forums/4-...haft-swap.html
stangalator is offline
Old 07-09-2009, 11:04 AM
Sxynerd
Sxynerd's Avatar
I wish I knew more to help you out but if I remember correctly there isn't a gear that's going to be perfect and it will always be off a little. (I'm not 100%)
Sxynerd is offline
Old 07-09-2009, 01:05 PM
stangalator
Hey sxynerd, what did you end up doing to fix your speedometer when you did your gears?
i ended up going to ford to get the 6 tooth drive gear, part #: E3ZZ*17285*B
I still need to order a 20 tooth speedo gear, I guess i can live with 1.37% too fast.
Gary Ugarek
63
12-11-2015 02:01 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Figure8allday
08-22-2015 11:11 AM
ding56
08-14-2015 02:40 AM
dfw692
08-07-2015 11:53 PM
Quick Reply: t45 drive gear swap
