5.4 block with 4.6 heads?
Old 10-13-2009, 01:34 AM
Lance9386
Lance9386's Avatar
Default 5.4 block with 4.6 heads?
2007 Mustang GT 4.6 Hellion turbo kit 62mm turbo 39 lb injectors dual cobra fuel pumps
I am looking into purchasing a built 5.4 block and turning up my boost! Could I use my 4.6 heads with this and still gain considerable power? I make 500rwhp the way the car sits now with stock motor and hellion turbo kit. Not very knowledable when it comes to building motors. Chime in and educate me please!!
--Just noticed I posted in the wrong section..sorry!!
Lance9386 is offline
Old 10-13-2009, 05:18 PM
dimebag
dimebag's Avatar
Yes you can. And its ok we have a good bit of 5.4 knowlege in here. But yup simple answer is yes u can, because the heads are the same ne way
dimebag is offline
Old 10-13-2009, 05:54 PM
pcs
pcs's Avatar
you have to get a 3v 5.4 block
you can swap 4.6 2v/4v heads on a similar 5.4 block but not 3v heads
pcs is offline
Old 10-13-2009, 07:49 PM
dimebag
dimebag's Avatar
Why not?
dimebag is offline
Old 10-13-2009, 08:17 PM
GeritGoul
GeritGoul's Avatar
the 5.4 will just sit right in the engine bay? no modifications? ?
GeritGoul is offline
Old 10-13-2009, 08:42 PM
4.698GT
4.698GT's Avatar
modifications to the exhaust will be needed and if you opt out of the s197 throttle, there will be some tinkering there.
4.698GT is offline
Old 10-13-2009, 08:48 PM
Sxynerd
Sxynerd's Avatar
The 5.4 has the same crap internals as the 4.6 and if you install the 5.4 you better have some amazing heads to go on it cause you're going to run out of air for any real RPM's and boost. Why don't you spend some time searching the site on your topic. Everything you need to know has already been said.
Sxynerd is offline
Old 10-13-2009, 09:13 PM
Fobra
Banned
Fobra's Avatar
3v heads are a straight swap. Just make sure you buy an 03+ "NVH" 5.4 block, not that you really HAVE to, but its a stronger block and will run quieter.
Fobra is offline
Old 10-14-2009, 08:21 AM
Lance9386
Lance9386's Avatar
Thanks guys
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
Drastang
09-30-2015 03:48 AM
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: 5.4 block with 4.6 heads?
