96 GT mustang
Old 11-03-2009, 03:27 PM
TAcaves60
TAcaves60's Avatar
Default 96 GT mustang
well my gf has a 96 mustang GT, and she is pretty crazy about drag racing , im a LSX guy so this is new ground for me and i dont like what i've been reading about 96 4.6L motors but i guess i gotta work with what is there. Any ideas on good mods for these motors? Thanks
TAcaves60 is offline
Old 11-03-2009, 03:36 PM
mrtstang
mrtstang's Avatar
Welcome to MF! Well since she has the NPI mod motor, she unfortunately has one of the weakest 4.6's out of the bunch. These cars respond well to forced induction. If you guys are looking for something a little cheaper, a PI swap (heads, intake, and cams) with a full exhaust is good. More aggressive gears help these cars a lot too.
I guess it really boils down to how much you want to spend.
mrtstang is offline
Old 11-03-2009, 03:52 PM
JC316
JC316's Avatar
To crack 350RWHP its going to have to be nitrous or forced induction. You can get some serious power increase from PI swap.
JC316 is offline
Old 11-03-2009, 04:02 PM
TAcaves60
TAcaves60's Avatar
Ok well what consits of a PI swap i understand intake, cams, and heads but what really is the meat and pataoes of the swap, and if im swaping cams ill probably go with a decent size aftermarket cam, as far as heads am i looking for stokc heads off a newer motor or aftermarket, as well for the intake
Old 11-03-2009, 04:27 PM
JC316
JC316's Avatar
Pretty much a direct bolt on. Use the search, there are tons of writeups on it.
JC316 is offline
Old 11-03-2009, 04:32 PM
TAcaves60
TAcaves60's Avatar
Thanks!
Old 11-03-2009, 04:48 PM
mrtstang
mrtstang's Avatar
Hey, what's done to your TA? I had a 98 Z28 before i got my stang, and wished i would've taken that motor out, and put it in my gt instead...lol. Those LS motors are awesome!
mrtstang is offline
Old 11-03-2009, 11:01 PM
MU71L4710N
MU71L4710N's Avatar
ok the thing is, if you do a pi swap its stupid cheap. you can get the heads cams and manifold for usually a few hundred bucks maybe a little more. to put in some decent aftermarket cams you will be spending 500+ on the cams, 250 on valvesprings, and everything else still needed. if you WANT to put in some better cams go for it, but it will substantially increase the cost.
you notice how the 99-04 gt's have 260hp and the 96-98 have 220, its because of the above mods. you can get the H/C/I from a newer car for cheap, bolt it on fairly easily, flash the ecu and your good to go and you will actually have a little more than 260hp because the timing is slightly higher on the NPI (96-98) GT's.
that would be my first mod if i were you. pretty cheap to do and nets a very nice hp gain as well as a better power band in the upper RPMs. unfortunately these cars dont respond nearly as well to boltons as your LS1 does. full boltons and a pi swap you will see maybe 270rwhp with a 5speed. how much is yalls budget for the car, is she opposed to FI, is this a DD car or a weekend toy?
MU71L4710N is offline
Old 11-04-2009, 12:08 AM
nascrchi
nascrchi's Avatar
check this out for your PI swap
https://mustangforums.com/forum/sn95...nd-intake.html
nascrchi is offline
Old 11-04-2009, 07:45 AM
98redstang
98redstang's Avatar
check my sig i did the pi swap with p & p heads. My tune sucks too cause my back brakes were dragging and the pilot bearing was missing... My timing wasnt even touched. Im hoping to break the 300rwhp mark with stage II cams and a 93 tune.
98redstang is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
chain
08-17-2015 08:52 AM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 96 GT mustang
