Last edit by: IB Advertising
Browse all: Brake Guides
- Ford Mustang Gt 1996 to 2004: Why is ABS Light On?
Guide to diagnose trouble and recommended solutions
ABS light on.
hasnt happened again, if it does i will definately look to see, i didnt really notice since i was on the highway maintaining speed, as soon as i got off i turned the car off then on and it hasnt happened again, dont drive it much cuz im in love with my F150 right now lol
265/40/18 in the back, my bad cliffy
Those are 1.0" (4.0%) larger diameter than the the 265/35-18s in the front. I do not know what the exact curves used for ABS and t/c are, however that's a pretty large difference.
What is curious is that the t/c turned off as well, I can find no mention of that interaction in the ABS or t/c sections of the shop manual...
I had the same problem, it turned out to be a little sensor over the brake pedal, the wires were not making good contact. I got it fixed because my shifter wouldn't move, the brake lights were not coming on. We bought some connectors and connected the wires, the brake lights worked and the abs light turned off now the traction control button works too.
AutoZone scans this problem for you, at no charge...
on my 01 GT, the ABS light is always on, the ABS absolutely doesnt work, and the trac-0ff light is always lit, and also..definetly doesnt work.
I dont have a scanner yet, if I take the car ot Auto-Zone, will their free scan tool explain what needs to be replaced? Like wheel sensor, tone ring, something?
The code on the scanner came back indicating that the ABS warning system was not getting a proper signal, presumably from the ABS sensor - hence the warning light. The brakes themselves work fine. The warning light simply comes on at intermittent times.
Research indicates 1 of 2 possibilities...
1) The connection (damaged wire, loose connector plug, etc.) may be faulty. This can be ascertained with a visual inspection. The sensor harness is located near the axle, close to the wheel. No way to tell how bad the damage - or how complicated the fix - until you inspect it.
2) The sensor itself may be faulty. If you rule out the faulty connection hypothesis (above), it is likely the sensor itself that will need to be replaced. Not sure if AutoZone handles a replacement part for this. A Ford dealer surely will, but the cost will be higher - likely $75 or so for each sensor (and each wheel has a separate sensor).
Here is a good diagram of the sensor (for a 2004 Mustang GT rear sensor)...
http://www.allfordmustangs.com/forum...ensor-rear.doc
Good Luck...
