quick question on degreeing shr cams
Old 12-19-2011, 04:43 PM
school boy
school boy's Avatar
Default quick question on degreeing shr cams
2760 Hot Street/Strip N/A Camshaft. Duration @ .050 242/232 Lift .550/.550 LSA 113. 3.27-4.10 gears, 2000+ stall converter, rough idle. RPM Range 2000-6500. Needs exhaust, intake
what i need to know is the centerline to degree the cams to. mods are:
flat top pistons
ported pi heads
ported svo intake
crane valve springs
titanium retainers
manley intake valves(standard size)
school boy is offline
Old 12-19-2011, 05:27 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
flat top pistons
ported pi heads
ported svo intake
crane valve springs
titanium retainers
probably in the 109* range
please tell me you have valve reliefs...
sn95_331_GT_ yellow is offline
Old 12-19-2011, 06:15 PM
school boy
school boy's Avatar
they currently dont. if there isnt enough clearance then the pistons will be sent out to be notched. the car these cams came out of didnt have notches but the cams were never degreed properly so not for sure how much the stock cam gears retarded the cams. the manley valves will give me .030-.040 more clearance but we will see if its enough. btw, the motor is on a stand so assembly/disassembly is easy. heres a video of the exact car they came out of:
http://youtu.be/KbRvAeq7Mh8
mtgldr
02-03-2024 09:00 PM
tmdm
05-02-2021 02:49 PM
ctgreddy
09-20-2015 08:35 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: quick question on degreeing shr cams
