Need Help With Head/Cam Setup
So right now all that's done to my 03 4.6 is a 78mm throttle body and plenum, a steeda cold air intake and a productions performance lower intake. Now I'm looking for a heads/cams setup and I found a deal on some patriot performance stage 2 heads and I want to run some nice cams. The only thing is I need to know what size cams I can run with these heads. Thanks for the help in advance. - here's the info on the heads - Patriot Performance Fully Assembled
Stage 2 Heads
Fits 1996-2004
GT Mustang •11 Bolt Valve Cover Design
•PI Romeo Castings
•Fully Assembled
•.600″ Lift Springs
•Titanium Retainers
•Stainless Steel High-Flo 1.78″ / 1.452″ Valves
•Stage II 5 Axis CNC Ported, Polished
•Built to Order
•Allow 3-4 Weeks
•ALL Spark Plug Threads Upgraded from 4 to 8 Threads
Stage 2 Heads
Fits 1996-2004
•PI Romeo Castings
•Fully Assembled
•.600″ Lift Springs
•Titanium Retainers
•Built to Order
•Allow 3-4 Weeks
Maybe somebody here can elaborate a little, but last I was aware Patriot heads were known to have some quality issues, iirc something to do with the valve seats. And I thought Patriot went out of business? Just do your homework before pulling the trigger on those, as there are other options for PI casting heads such as MHS, Fox Lake and MMR which are all known to be good stuff as far as I'm aware. Personally out of those threeI would probably go for MHS.
Otherwise I agree with the comment about TF heads, but you gotta open your wallet up pretty wide for those 'uns.
