Cooling issue (Fan - I think)
Be quite honest, on a mild setup, I have never heard of a properly working coolant system and fan give anyone trouble. You could rewire the secondary ac fan to come on with the other also but depending on what exactly you have, its hard to know if it will cool properly.
I suppose it could be the water pump not functioning properly, or radiator is clogged up and needs a flush (the guy I bought it from said the rad is less that a year old, so I have a hard time believing it would be all gunked up)
Being a 96, its 20 years old and most cars just flat out need the maintenance. But since it only gets warm at idle and low speeds and only kicking on one fan, I'm betting its the fan setup. You could try hard wiring the ac fan to the battery and drive it around and see if it gets hot. But again, since I don't know your fan setup, I don't know how well it works.
Codyclmn9
08-15-2021 06:50 AM
matt_90lx
02-24-2016 06:39 AM
Jonathan Davis
02-20-2016 11:14 PM
