2006 GT w/Whipple Missing and Stumbling after a run thru gears?
Iran the car thru 2,3,4 and let and it started to stumble. The check engine light came on. I think it is a spark plug? Or a coli pack? Any ideas? The X-Cal is say DTC read Error? ANy ideas?
Car is stnbling bad and less power?
2006 Mustang GT 6400 miles. HO Whipple Charger. Stock other wise.
RE: 2006 GT w/Whipple Missing and Stumbling after a run thru gears?
What about your fuel pump?
With that set up did you need to upgrade to a higher flowing fuel system?
To me it sounds like you might be starving the motor for Fuel.
Or you could be running dangerously LEAN<<
Are you using the stock whipple tune? Do you have a tuner so you can read the trouble codes?
How long have you had the whipple? Who installed it?
musnicki
09-23-2015 07:11 AM
DrunknRuckus
08-23-2015 10:05 AM
