Effects of Lean and Rich Tuning on mustang
Old 02-10-2012, 01:44 PM
deltafool117
deltafool117's Avatar
Default Effects of Lean and Rich Tuning on mustang
How much is too lean or too rich. I have an SCT X3 and it reads 0.0 Lean, 2.0 lean, 4.0 lean etc etc or 2.0 Rich, 4.0 rich...etc etc
I have been bouncign from 2.0 Rich to 2.0 Lean just to be safe. I do not want to damage my engine. It is calibrated for 93 octane as well.
For fuel efficiency is 93 or 91 better... thanks.
deltafool117 is offline
Old 02-10-2012, 05:32 PM
JCON
JCON's Avatar
higher octane is better for everything but your wallet. Higher octane allows the timing to be advanced thereby letting in more air to hopefully completely burn all of the fuel going in. Efficiency.
Going to lean or too rich is dangerous to the engine. Most engines run rich at higher rpm. I would wait for a tune to respond though since I've never played with the tunes, only loaded them.
JCON is offline
Old 02-12-2012, 11:17 AM
DTMR
DTMR's Avatar
the thing that no one seems to have an answer to, that kinda bugs me is the whole standalone ecu thing. Apparently no matter how rich our lean we run the engines with the act we are still reading it through a narrowband reading and you're supposed to go to through a wideband sensor, and if you can't make your pcm accept the wideband reading you are only tuning so much but still there seems to be no standalone ecu for the s197 and no one seems to know if we can tune the stock computer to accept the wideband readings
DTMR is offline
djbigskrilla
09-20-2022 01:04 AM
01blackgtconv
08-14-2015 04:50 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
whatsup62
08-11-2015 08:45 AM
Quick Reply: Effects of Lean and Rich Tuning on mustang
