is a 30mm offset too small??
Old 05-18-2012, 12:17 PM
DTMR
DTMR's Avatar
Default is a 30mm offset too small??
I was thinking of ordering some wheels but they have a 30 mm offset, I know that 32mm is okay but I wanted to make sure before i got them any help?
DTMR is offline
Old 05-18-2012, 12:26 PM
waykooljr
waykooljr's Avatar
What is the wheel width?
waykooljr is offline
Old 05-18-2012, 02:47 PM
DTMR
DTMR's Avatar
It is an 18x9.5
DTMR is offline
Old 05-18-2012, 06:14 PM
waykooljr
waykooljr's Avatar
I'd say no for the front, possibly on the rear.
The front would be out past the wheel arch by ~1/4" before the tire is mounted and I don't know if there would be suspension clearance issues with a 9.5" wheel.
Old 05-18-2012, 07:21 PM
DRock
DRock's Avatar
Suspension clearance there would be none. It will poke a little in the back but the front you could get to fit fine with some camber
DRock is offline
Old 05-18-2012, 07:25 PM
waykooljr
waykooljr's Avatar
Actually in answer to your question, yes, 30 mm is too small for the front, is what I should have said.
My previous reply is meant as to not use that offset on the front. Sorry if I caused confusion.
Old 05-18-2012, 11:01 PM
DTMR
DTMR's Avatar
I dont mind if it stcks out of te wheel well but your saying it wont fit?
DTMR is offline
Old 05-18-2012, 11:03 PM
DTMR
DTMR's Avatar
Sticks out of the* and they are all the same size and its the only ones i can get like that. So i shouldnt get them? I know 32mm is fine so would 30mm be a big deal
DTMR is offline
Old 05-19-2012, 08:50 AM
DTMR
DTMR's Avatar
What about 35mm front and 30mm rear
DTMR is offline
Old 05-19-2012, 09:10 AM
CaptainRon
CaptainRon's Avatar
45mm is the correct offset for '05-current Mustangs. But it really depends on what you plan on doing with the car. Street driving, road racing, 45mm is the way to go.
CaptainRon is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
daltron
04-28-2016 08:10 PM
UrS4
09-30-2015 10:13 AM
gagemcc
09-22-2015 09:43 AM
Quick Reply: is a 30mm offset too small??
