Timed runs on my 91 2.3/AT Convertible
Timed with aDyno app on a mytouch phone...
1991 Mustang Convertible 2.3/AT, 215/70-14 tires on stock polycast steel wheels
Manually shift at 5k rpm, Computer reset, 87 octane gas, full tank, 80 degrees, 8pm.
All stock except:
1. intake resonator gutted
2. maf screen removed
3. intake hot air tube disabled
4. air box intake tube altered to improve flow
5. a/c belt rerouted to 87-90 style (smaller belt, no longer on crank)
6. trunk gutted (-50 lbs)
0-30 mph: 5.40 sec
0-60 mph: 14.78 sec
0-80 mph: 21.72 sec
60 ft: 3.50 sec
1/8 mi: 13.55 sec @ 56.5 mph
1/4 mi: 20.33 sec @ 76.5 mph
Don't laugh, I know it's slow. Next step is to see if the udp is going to liven it up...
All stock except:
0-30 mph: 5.40 sec
0-60 mph: 14.78 sec
0-80 mph: 21.72 sec
60 ft: 3.50 sec
got impatient and just relocated the cam gear on the existing belt. car slowed down... GRRRR
i heard that they like the cam timing retarded but one full tooth?? now thats one MILD factory cam if it likes that much retard.
OK, adjustable cam gear and new timing belt are installed and just did lots of runs...
Best cam gear setting seems to be -2 degrees. I finally broke into 19's in the 1/4 mile... Woo Hoo ... Haha
All stock except:
1. intake resonator replaced with 2.75" aluminum tube
5. w/p-alt-ps belt rerouted to no longer be on crank
7. Accel hi flow drop in filter element
8. Esslinger Cam Gear (set at -2 degrees)
9. Ford Ranger Crank Pulley (run on outside pulley only)
10. T-Bird Turbo Cpe W/P Pulley
11. 63mm Alternator Pulley
Best run:
0-10 mph: 1.18 secs
0-20 mph: 2.92 secs
0-30 mph: 4.90 secs
0-40 mph: 7.28 secs
0-50 mph: 10.23 secs
0-60 mph: 13.69 secs
0-70 mph: 17.35 secs
0-80 mph: 20.04 secs
60ft: 3.32 secs
330 ft: 8.64 secs
1/8 mile: 13.00 secs @ 58.3 mph
1000 ft: 16.68 secs
1/4 mile: 19.65 secs @ 78.8 mph
All stock except:
Best run:
0-10 mph: 1.18 secs
0-20 mph: 2.92 secs
0-30 mph: 4.90 secs
0-40 mph: 7.28 secs
60ft: 3.32 secs
330 ft: 8.64 secs
1000 ft: 16.68 secs
New run with new parts!
My exhaust manifold was cracked and my cats were blown out so I added a Ranger header, 2 1/4" pipe with a Mustang 5.0 cat between it and the flowmaster that was already on the car.
The car got loud... too loud for my tastes so i'm planning on a muffler and tailpipe change.
The exhaust changes seemed to help low rpm torque but made things softer on the top end (hp), notice the slower 1/4 mile trap speed and the slower 0-80 than before the exhaust change... go figure.
New times:
All stock except:
9. 1992 Ford Ranger Crank Pulley (run on outside pulley only)
10. 1988 T-Bird Turbo Cpe W/P Pulley
12. 1993 Ranger tube header w/ egr fittings (another 20 lb weight loss)
13. 2.25" headpipe and CARB approved Mustang 5.0 cat. (one less cat and lighter tubing, -10lbs)
Weight wise, I've shaved 80 lbs from the car since I started.
Latest run:
0-10 mph: 1.14 secs
0-20 mph: 2.83 secs
0-30 mph: 4.72 secs
0-40 mph: 6.97 secs
0-50 mph: 9.81 secs
0-60 mph: 13.26 secs
0-70 mph: 17.01 secs
0-80 mph: 21.41 secs
60ft: 3.28 secs
330 ft: 8.50 secs
1/8 mile: 12.81 secs @ 58.8 mph
1000 ft: 16.45 secs
1/4 mile: 19.49 secs @ 74.9 mph
New times:
All stock except:
Latest run:
0-10 mph: 1.14 secs
0-20 mph: 2.83 secs
0-30 mph: 4.72 secs
0-40 mph: 6.97 secs
0-50 mph: 9.81 secs
60ft: 3.28 secs
330 ft: 8.50 secs
1000 ft: 16.45 secs
And we have another successful run...
Added new 2.25" Intake Tube assy to car and since it was a similarly nice day as were previous runs, i took her out.
All stock except:
1. intake resonator replaced with 2.75" aluminum tube REPLACED WITH #14
14. My design 2.25" Intake tube
0-10 mph: 1.04 secs
0-20 mph: 2.66 secs
0-30 mph: 4.49 secs
0-40 mph: 6.59 secs
0-50 mph: 9.19 secs
0-60 mph: 12.45 secs
0-70 mph: 16.63 secs
0-80 mph: N/A
60ft: 3.17 secs
330 ft: 8.29 secs
1/8 mile: 12.49 secs @ 60.1 mph
1000 ft: 16.09 secs
1/4 mile: 19.11 secs @ 75.3 mph
All stock except:
0-10 mph: 1.04 secs
0-20 mph: 2.66 secs
0-30 mph: 4.49 secs
0-40 mph: 6.59 secs
0-50 mph: 9.19 secs
0-80 mph: N/A
60ft: 3.17 secs
330 ft: 8.29 secs
1000 ft: 16.09 secs
bond007
08-26-2015 11:36 PM
