4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
High NOx(smog help)
Old 10-23-2011, 12:20 AM
90notchback
90notchback's Avatar
Default High NOx(smog help)
What can I fix to lower the high NOx numbers?
Test 15mph
Rpm 1754
%CO2 meas; 14.8
%02 meas; 0.0
Hc(ppm) max: 86 meas:37
Co(%) max: 0.54 meas;0.02
NO(ppm) max:565 meas:660
Test 25mph
Rpm 1714
%CO2 meas; 14.8
%02 meas; 0.0
Hc(ppm) max: 67 meas:28
Co(%) max: 0.45 meas: 0.02
NO(ppm) max:522 meas:539
Results fail
90notchback is offline
Old 10-23-2011, 12:21 AM
90notchback
How can I lower the high NOx numbers?
Test 15mph
Rpm 1754
%CO2 meas; 14.8
%02 meas; 0.0
Test 25mph
Rpm 1714
%CO2 meas; 14.8
%02 meas; 0.0
Results fail[/QUOTE]
Old 10-23-2011, 02:33 PM
my4ateyour8
my4ateyour8's Avatar
What did the code reader or scanner tell you when you tested it? I mean the OBD I tester not the emissions tester. The Ford OBD I computers give out very little information but you do get a starting point. I had a 88 notch with a 2.3 that ran really bad and the computer gave me 3 or 4 things to check which I did with an electrical tester/ohm-meter and was able to fix it. Too many years ago to remember all the particulars.
my4ateyour8 is offline
Old 10-24-2011, 01:05 PM
90notchback
I do not have an obdI scanner so I wouldn't be able to provide any codes. I reviewed the smog test paper and it appears to shows that my timing is at 15* but the guy didn't fail me. How can I check the timing without a timing gun. I cleaned out the egr valve it was somewhat dirty, I checked if it was working when vaccum was applied and the orange rubber inflated fully which Im guessing means its working.
Old 11-04-2011, 11:40 PM
my4ateyour8
There is a way to check the codes by turning the key on and off a certain number of times to jog the computer's memory (unless my memory is bad too) or by inserting a jumper in the test plug. You may find this info in a repair manual. I moved recently and mine is still in a box somewhere or I would try to give more information. You might be able to find this info by googleing or something.
Once you find the info to check the code you get the code number by counting the check engine light flashes and then you can look up the info in your manual for a starting point.
Hope this helps.
Old 12-02-2011, 06:57 PM
USAiron
USAiron's Avatar
make sure your egr is working properly. i went through HELL in texASS with my stock, 1.5, honda del sol. it never passed the nox because the 5sp cars didn't come with EGR as did the automatics. the computer wasn't notified.... i'm glad to be outa that S-hole...
USAiron is offline
CS2007
06-25-2019 09:45 PM
Drastang
09-30-2015 03:48 AM
Teddi
09-29-2015 12:24 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: High NOx(smog help)
