A/C eliminator belt??
Old 04-09-2006, 06:19 PM
88blackCONvert
88blackCONvert's Avatar
Default A/C eliminator belt??
Just got the ford racing A/C eliminator bracket, but it didn't say what belt to use. I bought the belt for mustang with out factory a/c, and the belt is a bit too long. Anyone know the part number for the belt i need??
88blackCONvert is offline
Old 04-09-2006, 06:30 PM
88blackCONvert
Default RE: A/C eliminator belt??
I searched through the threads and found this part number
FMS-M-19216-A50
This one is for a 94' mustang, so will it fit my 88'? By the way, the kit was the bracket that moved the power steering pump to where the A/C was at.
Old 04-09-2006, 06:32 PM
marx91
marx91's Avatar
take a piece of string or what not and wrap it around the pulleys to get the measurement you'll need
if you have underdrive pulleys and no smog the belt length is (73" 3/4)
marx91 is offline
Old 04-09-2006, 08:59 PM
Suspect
Suspect's Avatar
if ur bought the fr ac eliminator, i thought the stock belt works. if anything do the string trick.
Suspect is offline
Old 04-09-2006, 09:08 PM
primetime5.0
primetime5.0's Avatar
go to the parts store and try belts out front till you find one that works
primetime5.0 is offline
Old 04-09-2006, 10:32 PM
88blackCONvert
Thats what i did. The factory belt with no A/C was about 1" too long, but i just made a couple trips back and forth from the parts store, and finally got the right one. Thanks fellas.
Old 04-10-2006, 04:16 AM
dirtrancher
dirtrancher's Avatar
Did the same thing today. Took me 3 trips to get the right one.
If using Goodyear belts, the last 3 digits of the belt number is the length in inches. Example, a belt ending in 790 is 79.0 inches long, 765 is 76.5 inches , etc.
With stock pulleys and the smog pump intact, I ended up using a 775. I think a 765 would have been better but they didn't have one in stock.
Would have been nice if the AC Eliminator kit had specified.
Maybe this will help the next guy...
dirtrancher is offline
vargas
06-17-2017 12:17 PM
Florida Regional Chapter
09-30-2015 08:04 PM
69Volunteer
09-30-2015 10:39 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: A/C eliminator belt??
