speedometer gear swap
Old 04-10-2006, 06:11 PM
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
Default speedometer gear swap
courtesy of gspfunk [sm=smiley20.gif]
Changing out your speedo gear is EASY, for those of you who don't already know this. I did mine Saturday before I put my new tranny back in. Here's the steps (w/ pics):
Pic 1--The housing for the speedo gear is located at the rear of the tranny.
Pic 2--There is one bolt (7/16 wrench or socket) on the retainer keeping the housing in place. Remove the bolt and the clip slides out toward the bolt side.
Pic 3--This is the housing w/ the current speedo gear.
Pic 4--A small flathead screwdriver will remove the clip holding the speedo gear in place and then it just slides off. The speedo gear slides on to a square peg, so just rotate it a little as you slide it on and it should go w/o any force.
Then just replace the clip on the speedo gear, slide the housing back in (facing same direction as before), and replace the housing retainer and bolt.
HC_CrAzYHoRsE is offline
Old 02-05-2009, 02:20 PM
cholericfc
cholericfc's Avatar
So if I had changed my gear size, and then replace with the right gear, this should fix the incorrect gauge measurement?
cholericfc is offline
articman
06-21-2018 11:45 PM
musnicki
09-23-2015 07:11 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: speedometer gear swap
