Eliminating smog pump
Old 04-11-2004, 02:42 AM
fantasyfords
fantasyfords's Avatar
Default Eliminating smog pump
How much can you gain from taking off your smog pump?
fantasyfords is offline
Old 04-11-2004, 02:53 PM
BPLax21
BPLax21's Avatar
Default RE: Eliminating smog pump
if you eliminate the smog pump and ac and run a shorter belt, ive heard u can decrease 1/4 times by 2 tenths. i took mine off, and it was easy to do.
BPLax21 is offline
Old 04-11-2004, 07:32 PM
fantasyfords
cool thanks
Old 04-11-2004, 07:47 PM
VertStangGT86
VertStangGT86's Avatar
The smog pump's on the bottom right isn't it? That would be as if you were sitting in the driver's seat and that's the left side. Also if you take that off what do you do to the lines coming out of it? I know they go back to the block/heads or right around there, can't quite picture it right now.
VertStangGT86 is offline
Old 04-11-2004, 07:58 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
EH?
Just say the driver's side of passenger's side.....make things easy.
jeep45238 is offline
Old 04-11-2004, 08:54 PM
vfast
I ♥ Acer
vfast's Avatar
just bypass it with a short belt and leave it on...bypassing the a/c might be .5 hp as there is little drag with it as the only benifit is only the wt issue and then if you have the spare tire in the car you would do better to remove it
vfast is offline
Old 04-11-2004, 10:42 PM
Moosetang
Moosetang's Avatar
How will the computer respond to eliminating it?
Moosetang is offline
Old 04-11-2004, 11:41 PM
VertStangGT86
OK, when you talk about sides the driver's side is the left side, I was just trying to clarify it cause a lot of people seem to talk about sides as if you were looking at the engine. I just didn't want to get people trying to tell me it was on the other side.
Old 04-12-2004, 12:57 PM
Stinger
Stinger's Avatar
LOL what if the car was made for England?[sm=smiley4.gif]
Stinger is offline
Old 04-12-2004, 02:15 PM
BPLax21
BPLax21's Avatar
the smog pump is on the passenger side of the car. it is below the alternator. and heres how u remove it .
ok heres how u take off ur smog pump. 1. remove the belt. 2. remove the 2 bolts holding the pump on. 3. remove all the tubing and hoses connescted to it. 3. cut the 2 vaccum lines shorter if u want, it looks better if there shorter and plug them( i used 2 small screws). 4. use the one hose that is bent kinda like a u, i trimmed this hose so it was a perfect u and connected the tube from the heads to the tube that goes down to the h-pipe, if u trim it it works perfectly and use hose clamps to hold it on. 5. If you have already removed ur ac also then a 71" belt will be the belt u need to use. be sure that you reverse what side the belt goes around the water pump though. stock it comes up on the right of the water pump, on this u need to make it come up on the left side. and your done.
BPLax21 is offline
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Eliminating smog pump
