TB stud bolts on new Intake...
Hey, i am putting a new TB on my Edelbrock manifold and it didn't come with the 4 stud bolts that you use to mount the TB on it. I was wondering if anyone by any chance knew the size of the bolts? type threading?
RE: TB stud bolts on new Intake...
Just in case you were having problems you have to put the wrench on the bottom of the two nuts. I like doing that even more then stud removers, they'll damage the threads. I've used two nuts even when I've had stud removers handy.
soak the old studs with penetrating oil first as they tend to be galled in the aluminum and use the two nuts method mentioned already. other option is to take the nuts to the hardware store and match them up and buy some new studs anyway. put some never seize compound on any ones you use and they won't be so hard to remove later either.
maestro1024
09-21-2015 02:40 PM
