rear main seal
Old 06-05-2003, 11:36 AM
89muscle
89muscle's Avatar
Default rear main seal
the motor doesnt have to come out when you remove the rear main seal in a 89 mustang gt right? im plannin on doing it this saturday so i need to know now. i think there is about a half an inch between the oil pan and the k-member so i think that i can pry it out with a few sheetmetal screws in the seal. Does anyone know how hard the front seal is to remove?
89muscle is offline
Old 06-05-2003, 01:39 PM
converted
converted's Avatar
front seal will be easier than the rear one. But you will have to remove the accessories to do it right. You could probably try to remove with w/a screwdriver, but you might damage something that way. Best thing to do is to remove the timing chain cover and replace the seal that way.
converted is offline
Old 06-05-2003, 01:53 PM
Sean
Sean's Avatar
I have done a rear main on a 302 without pullin the engine.But that was is a 72 bronco with a 2" lift, lots a room to move arround under there.
Sean is offline
Old 06-05-2003, 02:12 PM
89muscle
89muscle's Avatar
i have to lower the oil pan right? cause if any one has done it on a stang i need to know. i dont want to take it all apart and not be able to. i can take it apart in about a hour so it wont be a problem. if any one has any suggestions please help
89muscle is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
Demodulates
09-18-2015 11:14 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
09-01-2015 08:16 PM
Quick Reply: rear main seal
