3:73 Gear Speedometer Change Instructions
Old 06-13-2004, 03:38 PM
BPLax21
BPLax21's Avatar
Default 3:73 Gear Speedometer Change Instructions
I have 3:73 gears in the car and i never have changed the speedo gear to compensate for the different gears. I have the new gear i just need to know how to install it. Please give me some dirrections. thanks
BPLax21 is offline
Old 06-13-2004, 05:17 PM
NOS/MAN
I ♥ Acer
NOS/MAN's Avatar
Default RE: 3:73 Gear Speedometer Change Instructions
get under car look where cable goes into trans unbolt it 10mm ,,,take cable out it has a clip on the gear take clip off,,install new gear put c clip back on,,tighten bolt and go drive,,check for leak after you drive it awhile....
NOS/MAN is offline
Old 06-14-2004, 12:20 AM
nhdungeonracer
nhdungeonracer's Avatar
Hardest part of this job is jacking the car up so you can crawl under it
If you have access to a lift, then you have a very easy chore ahead of you
It's as easy as NOSMAN makes it out to be, maybe even easier.
nhdungeonracer is offline
articman
06-21-2018 11:45 PM
carid
07-08-2016 09:55 AM
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: 3:73 Gear Speedometer Change Instructions
