AOD ?'s
Old 09-23-2006, 06:56 PM
sgt50
sgt50's Avatar
Default RE: AOD ?'s
Use to have an AOD in my 93GT. Killed the overdrive band in it one day, fixed and put in a shift kit and 3000 stall. Got tired of guys being able to kick down harder than me because they had 5 speeds. Sold the tranny, bought a T5 out of a cobra, don't know why i didn't do it sooner. It was an easy swap except putting in a cluthch assembley. Had to get some help.
sgt50 is offline
Old 09-24-2006, 10:22 PM
95 BLOWN GT
95 BLOWN GT's Avatar
Default RE: AOD ?'s
if you get a manual valve body will it shift if left in drive? or do you always have to shift it manually?
95 BLOWN GT is offline
Old 09-24-2006, 11:01 PM
FullAuto
FullAuto's Avatar
Default RE: AOD ?'s
I would not buy an Art Carr. I've had several of their AODs and every one of them as failed for one reason or another. It was always due to being poorly built, not from anything having to do with racing. I have a hard time deciding who makes a more inferior product, Art Carr or Kooks.
FullAuto is offline
Old 09-25-2006, 12:00 AM
fordboyyfm
fordboyyfm's Avatar
Default RE: AOD ?'s
ORIGINAL: FullAuto
thats the first bad thing ive heard about art carr. The trans guy at my work, used to work for ati and hes built allot of competion aods, said he was a good name and real good to deal with, and this was years ago before he got real big. i know im calling him tommorrow to order my converter and valve body with a transbrake.
fordboyyfm is offline
Old 09-25-2006, 12:23 AM
FullAuto
FullAuto's Avatar
Default RE: AOD ?'s
I bought their Extreme AOD rated to 800hp. The first one was broken when I received it. The car wouldn't move. I sent it back and never found out what was wrong. I broke the 2nd one with 262rwhp and the other 2 with less than 450rwhp. None of them were from racing. It was always something from just being poorly built. They were all having internal problems so it's not like th clutches went bad or wore out or anything. I went through 4 of them (including the first one that was shipped broken) in under 1,000 miles. The last time I have it repaired by them I sold it as soon as I received it. I just cut my losses and went with a PA Supercomp C4.
FullAuto is offline
Old 09-25-2006, 01:44 PM
inahury1
inahury1's Avatar
Default RE: AOD ?'s
I work with a Guy that used to race off road trucks in southern Califonia and He swer by Art Carr. They Build racing transmissions for many off road race vehicals.
I have a transgo shift kit in right know, I just don't like it I want that over drive delete!
I am really looking at the ART CARR valve body and there custum stall. About $1100 total.
inahury1 is offline
Old 09-25-2006, 02:10 PM
88BlueGT
88BlueGT's Avatar
Default RE: AOD ?'s
ORIGINAL: 95 BLOWN GT
It depends on what valve body you get. They have full manual VB's were you have to shift it everytime. And than they have street/strip VB's where you can hold each shift manually or just put it in gear and go and it will shift for you.
88BlueGT is offline
Old 09-26-2006, 12:45 AM
89GTRagtop
89GTRagtop's Avatar
Default RE: AOD ?'s
I currently have a B&M transpak shift kit with a Hammer shifter which is OK,but I was thinking of upgrading to a PA (performance automatic) valve body. I have heard good things about them from a couple of people.
89GTRagtop is offline
Old 09-26-2006, 01:19 AM
Twister
Twister's Avatar
Default RE: AOD ?'s
I have a lentech valve body, I love it!
I am running s stock shifter
You could wire the overdrive cut out switch into a GT headlamp switch...the fog lamp part...totally hidden
Twister is offline
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
TAC_Sisco
01-08-2004 06:33 AM
89 GT
11-18-2003 03:24 PM
MustangGT95
07-31-2003 02:56 AM
Quick Reply: AOD ?'s
