Cobra intake/what Cam and Heads
Just what the subject says...my other Fox (90'GT) has all the boltons exept an upgraded ignition,fuel system,bigger Mass Air,Cam,Head...Can someone fill in the blanks on what I need to order next??
RE: Cobra intake/what Cam and Heads
i would get a better intake or have yours ported as a Cobra is only good for 350 horse. The ARF's are the best but expensive. If you went with the AFR you wouldn't be getting all your power with that intake. If you wanna keepthe cobrago with Gt-40's. I would say GT-40X but if you wanna go cheaper get the Gt-40P's or turbo swirl,also an E cam 75mm mas air and 24Ib injectores. A 65mm throttle for the cobra, 70mm for any other. 190LPH pump or even 255 wouldn't hurt for later upgrades like supercharger. MSD 6AL and distributer.
How about this?? AFR 165,E Cam,24lb injectors,75mm Mas Air(which company??)1.6 rr, 255 fuel pump,MSD 6AL + distributor.....Also I noticed that you get an option with the AFR 165..58cc or 61cc configuration and stud mount or pedestal..which do I buy??? Thanx again
Really, if you're not going to buy everything at once, you need to get the fuel and ignition upgraded first. When you get that 255 pump, make sure you also get an adjustable fuel pressure regulator also. The rest of it you pretty much will have to do all at once. You might look into using trickflow twisted wedge heads as their special design will allow you to use a bigger cam than most other heads even with stock pistons.
