gears and the posi unit
got my girlfriend a 91 gt... auto....
i am putting in 4.10's but my question is
with the trac loc... if i get the rebuild plates, would i notice a difference? and what difference would i notice? would it brake loose around the right hand corners easier?
RE: gears and the posi unit
the rebuild discs will give you a bit better traction. Chances are the stock plates are getting a bit worn. These discs have friction material on them that wears out(like brakes and clutch). The rear end wont brake loose more around corners. Its a good idea to change the friction dics if your goin in there. Dont forget the friction modifier for those new discs.
KingRando
10-02-2015 08:06 AM
