Sub-Frame Connectors
Old 02-26-2007, 09:17 PM
91stang
91stang's Avatar
Default RE: Sub-Frame Connectors
i'm getting custom ones from a shop down here. i heard they were amazing
91stang is offline
Old 02-26-2007, 11:14 PM
Drexl
Drexl's Avatar
ORIGINAL: Arno
Through the floor if you are running big HP and racing. Daily driver or weekend racing would only require standard, weld in, full length connectors, if that.
but through the floor looks so damn cool.
Drexl is offline
Old 02-27-2007, 12:19 AM
92hatchLX
92hatchLX's Avatar
I'm getting the MM full lengths when ever I get some more money. I haven't heard very many bad things about them. I'm running blue oval industries subframes in my convertible though, they really stiffened things up. But I'm going to run full lengths in my hatchback just for ****s and giggles.
92hatchLX is offline
Old 02-27-2007, 12:47 AM
greenstreak9205
greenstreak9205's Avatar
how much more of a process is installing through the floor subframe connectors? i've always like the sound of the idea simply because of the strength they offer but wasn't sure if they would be worth the hassle.
greenstreak9205 is offline
Old 02-27-2007, 12:53 AM
Li0nHart
Li0nHart's Avatar
I would imagine you get the pleasure of removing your interior...cutting long narrow pieces of metal from the floor pan on each side...then you get to create approximately 24feet of welds to hold it all together...i would do it though...
Li0nHart is offline
Old 02-27-2007, 01:15 AM
deanzawistowski
deanzawistowski's Avatar
dosent really matter theyre all steel, just make sure they have seat supports and for shure go with the full lengths
i have some blue oval insudtries and i like them
deanzawistowski is offline
Old 02-27-2007, 02:08 AM
94gtmax50
94gtmax50's Avatar
when you weld the sub frames on, can it be done on a simple car lift at a shop or is it better to use a drive on ramp lift. i heard that if you weld on a shop lift your doors will not shut right because the frame is just hanging in the air. if you use a drive on lift the frame and suspesion is loaded and even . is that true.
94gtmax50 is offline
Old 02-27-2007, 02:10 AM
Drexl
Drexl's Avatar
Well.. I did mine when I had the new floors put in.. so it worked out well.
the in-floor ones are a lot more work, but DAMN are they strong
Drexl is offline
Old 02-27-2007, 03:46 AM
88BlueGT
88BlueGT's Avatar
Im running the Maximum Motorsports XL subframes.
88BlueGT is offline
Old 02-27-2007, 04:07 AM
Hung Like a Stang
Hung Like a Stang's Avatar
you have to do it on a 4 post lift, on the floor, or jack up the tires. Basically the car has to be stand as if it were not on a lift of any sort.
Hung Like a Stang is offline
jwog666
12-27-2021 08:09 PM
Seanam
10-04-2015 10:15 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
TfcCDR
09-14-2015 12:08 PM
Wombatnation
09-13-2015 09:16 PM
Quick Reply: Sub-Frame Connectors
