4.6 swap in 1992 Lx 5.0
RE: 4.6 swap in 1992 Lx 5.0
either you dont have a 383, or somethings not workin up there in that head of yours...
can you do the swap? yes, is it difficult? yes is it worth it over your current set up? negative.
unless its a terminator motor, i wouldnt even concider the effort
www.modularfox.com
just turbo that 383, make more power.
http://ff58modswap.bravehost.com/index.html
250 hrs and $30k
250 hrs and $30k
ORIGINAL: r.barn
www.modularfox.com
250 hrs and $30k
www.modularfox.com
250 hrs and $30k
I'm currently working on a modular fox, its a pretty fun swap. You need new kmember and a whole new drivetrain then wiring harness, cooling, relocate a few things etc.. I'm actually doing the swap on a 92 lx myself. Lots of modifications are done for this swap, I would suggest modularfox.com to read about it. For the long run i didnt plan for most horsepower per dollar, i went for uniqueness and overall orginallity(sp??) because ther are not nearly as many 4.6 foxs as there are 302s,331,347 etc etc. If you are looking for speed, take the 302 stroke and bore it to 347, put some afr 185s heads, a custom cam, trickflow type R box intake, then all the normal bolt ons and you will have 1 mean car, for alot less then the 4.6 swap would cost.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
