Heads?
Old 03-12-2007, 08:25 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
ported heads make about how much more than if they werent ported?
89gfoxlx is offline
Old 03-12-2007, 08:30 PM
ih8chevy
ih8chevy's Avatar
Default RE: Heads?
thats hard to say, it depends on a lot more than just port and non port heads. depends on the rest of the setup. but i would say u would see a 25-30 hp gain with well ported gt40 heads. thats just a guess though, dont take it to the grave.
ih8chevy is offline
Old 03-12-2007, 08:39 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
so on my stock lower end with gt40p heads ported and polished and gt40 intake ported and polished with the bbk 70 mm tb and 73 mm maf clibrated to 24 lb inj with a 255 lph pump, i should see over 300 rwhp?
89gfoxlx is offline
Old 03-12-2007, 08:45 PM
ih8chevy
ih8chevy's Avatar
Default RE: Heads?
with a cam^^^ not on the stock cam u wont. probably around 260 wheel with stock cam. get a b cam or trick flow 1 cam is a great cam. and with that u will c close to if not 300 wheel.
ih8chevy is offline
Old 03-12-2007, 08:48 PM
drhoward
Penis Mod Erator
drhoward's Avatar
Default RE: Heads?
you will get good numbers after a tune, you will not get all the benifits without a dyno tune
drhoward is online now
Old 03-12-2007, 08:53 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
Yeah I plan on having it dyno tuned when Im done. What would be better for rockers 1.6 or 1.7? Or do them heads come with 1.6's already?
89gfoxlx is offline
Old 03-12-2007, 09:01 PM
w8less
w8less's Avatar
Default RE: Heads?
when i you u do PLEASE POST THE RESULTS!
w8less is offline
Old 03-12-2007, 09:17 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
I definitely will. It will probbaly be a few weeks before Ill have time to tear it down.
89gfoxlx is offline
Old 03-12-2007, 10:33 PM
cassidymustang
cassidymustang's Avatar
Default RE: Heads?
get some better heads then thos. Try procomp. they are aluminum and if you get a assymbled set and you port and polish them you will see way better gains then the gt40s
cassidymustang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Heads?
