Blown head gasket?
Old 03-13-2007, 01:28 PM
paulstang
paulstang's Avatar
Default Blown head gasket?
What are some of the symptoms of a blown headgasket. I think i might have one but need to if the symptoms are the same.
THanks
paulstang is offline
Old 03-13-2007, 01:34 PM
Bumsdeclaf
Bumsdeclaf's Avatar
Default RE: Blown head gasket?
over heating, discoloration of oil because when oil and coolant mix at high temps they turn white. Ive also seen this happen in my cousins eclipse but in his case his oil turned coffee with milk color(brown) also sometimes you'll get foam in the radiator. anyway blown head gasket usually happens from a very bad overheating so if this happened to you before it might be the case
Bumsdeclaf is offline
Old 03-13-2007, 01:35 PM
Bumsdeclaf
Bumsdeclaf's Avatar
ive also seen bubbles on the dipstick
Old 03-13-2007, 01:38 PM
paulstang
paulstang's Avatar
ok i will check to see if i have any of that. will it also burn a little antifreeze. and will it cause you to not have power up top.
Old 03-13-2007, 01:41 PM
Bumsdeclaf
Bumsdeclaf's Avatar
i dont know about how it may affect performance but i wouldent jump on the accelerator if i were you, unless you want an excuse to buy new high performance heads. cause if the gasket is blown, next would be warped heads if they arnt already warped. if they are warped you could loose compression and might even see leaks where the heads meet the block.
Old 03-13-2007, 01:42 PM
93 LX FiveO
93 LX FiveO's Avatar
bubbles on the dipstick???
93 LX FiveO is offline
Old 03-13-2007, 01:46 PM
paulstang
paulstang's Avatar
ok well mine didnt over heat but it just doesnt seem right and it takes off hard in first gear but when you start going threw the gears it falls flat on its face. So i was just checking to see if that might be the problem but it seems to me like i have something else.
Old 03-13-2007, 01:53 PM
Bumsdeclaf
Bumsdeclaf's Avatar
yeah, bubbles on the dipstick. this happened once with a 427 chevy block my father was having rebuilt. apperantly they did not put the head gasket on right and there were bubbles of water on the dipstick(water does not mix with oil). Another symptom of blown head gasket could be unusually high oil pressure cause if coolant is mixing with the oil, its adding more fluid to the oil and increasing pressure.
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
Florida Regional Chapter
09-30-2015 08:04 PM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Blown head gasket?
