convertible promblems
Old 03-14-2007, 05:46 PM
Capital113
Capital113's Avatar
Default convertible promblems
I am looking for some help on my 92 lx 'vert
The top stopped working
I hear the top motor running but also heara bubbleing noise in the passenger rear.
Someone told me it was one of the two hydrolics and to replace it
Someone eles told me that the lines just need to be bled. 1stQ: is it possible to bleed this?
2edQ: If not is this a hard install for the lay mechanic?
Capital113 is offline
Old 03-14-2007, 05:52 PM
vt89gtvert
vt89gtvert's Avatar
Default RE: convertible promblems
First I would have someone press the button while you are in the trunk with the carpet panel removed looking to see exactly where the sound is coming from. Have you checked to see if the system has plenty of fluid??? there is a good description of how to do this in the covertible section if you look. It is under the general tech section. The hardest part about working on the vert is not having alot of room to work.
vt89gtvert is offline
Old 03-14-2007, 06:08 PM
p1bigun
p1bigun's Avatar
get in there and look for a leak cause you probably got 1
p1bigun is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
07-05-2020 03:05 AM
lovesilver
Members Mustangs
05-09-2019 09:18 PM
jerrytubes
10-23-2015 12:11 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: convertible promblems
