need help identifying a wire!
Old 06-18-2007, 01:16 AM
mattdel
mattdel's Avatar
Default RE: need help identifying a wire!
im going to look right now. gimme 5 mins
mattdel is offline
Old 06-18-2007, 01:23 AM
mattdel
mattdel's Avatar
ok i just went out and looked, with a flashlight and no mirror.
it goes down, right down the back of the motor, and starts curling down towards the passenger side. looks to go down past the lower intake.
my motor is too hot to trace it with my hand, but that should at least give you a starting point to look.
mattdel is offline
Old 06-18-2007, 01:44 AM
samseed101
samseed101's Avatar
ORIGINAL: pro tint
looks like its the H.E.G.O sensor ground. what is that???
An HEGO sensor is just a fancy name for what you probably know as an O2 sensor or Oxygen sensor. As you can imagine, it would be bad if that wire were cut or damaged, as it would screw up any readings from that O2 sensor. I'm guessing that either the wire is something else, or your car is running like crap and possibly triggering a CEL.
samseed101 is offline
Old 06-18-2007, 02:00 AM
pro tint
pro tint's Avatar
as of right now now that is the least of my worries, I cant even get the motor to start cause the injectors wont spray. I was really hoping that that wire would have solved my problem
pro tint is offline
Old 06-18-2007, 02:02 AM
mattdel
mattdel's Avatar
injector timing is controlled by the signal from the pickup module inside the distributor, and fed out through the TFI module.
test both of those too.
mattdel is offline
Old 06-18-2007, 02:27 AM
pro tint
pro tint's Avatar
ORIGINAL: mattdel
does the tps have anything to do with the injectors?
pro tint is offline
Old 06-18-2007, 02:28 AM
pro tint
pro tint's Avatar
ORIGINAL: samseed101
ORIGINAL: pro tint
thank you for those diagrams as they helped out alot
pro tint is offline
Old 06-18-2007, 03:50 AM
cleanfitty
cleanfitty's Avatar
It looks like the ground that goes to the bach of the block.
cleanfitty is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: need help identifying a wire!
